This will make the third time ive taken my clutch off. First two times not really a problem. This time a different story.
I dont have a clutch puller and can not find a 3/4" Fine thread anywhere in town with enough threads. So I used a trailer hitch ball and a piece of stock....it works or did the first two times. Lol. Ive had it so tight that the actuall stock has wore into the trailer hitch ball about a 1/4 inch. I backed it out and put a socket inbetween the stock and ball and the socket mushroomed
I quit messing with it when I thought it broke loose but actually I just seperated the "clutches" from the back wheel. You could free spin the clutch up the ball. But ball was still tight against stock/crank. Please tell me I didn't just ruin my clutch.
I dont know what else to try I got it as tight as possible and tapped it with rubber hammer. Im going to do my best to find a hard bolt and use an impact hoping it will pop it off. Oh yea the stock is stuck in the crank as well.
Any ideas? Is heat an option? PB blast? Bigger hammer? Is my clutch ok since it separated? Thanks
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
