1 - 14 of 14 Posts
I have not seen a 17" UTV wheel unless the new Pro/Turbo R 5 lug hubs can run a truck/Jeep wheel?
What is the 5 lug bolt pattern?
Edit: looks like the 5 lug pattern is 5x114.3 which is 5x4.5.
They have been offered long time ago all the way to 20”
Raceline A95B Trophy ATV/UTV 17x7 4x156 +10mm Black Wheel Rim 17" Inch https://a.co/d/gcD6fhJ
System 3 ST-3 18x7 ATV/UTV Wheel - Machined (4/156) 4+3 [19-0055] https://a.co/d/e1Beo3g
MSA OFFROAD WHEELS M36 Switch Machined 20" Inch 4x156 (3/8 Stud) Wheel/Rim 20x7 +0mm (Set of 4) https://a.co/d/fXesYMy
That’s awesome and 17 is perfect wouldn’t want any bigger. Unfortunately I just bought a set a 35 inch stickies with 15 inch method bead locks. If I’d known 3 months ago I would’ve waited. Hopefully they will release 15”
Really wish they would redesign the shoulder tread. Maybe even dual durometer with a little stiffer shoulder lug. Edge bite could be better.
I knew they made 18s and 20s. Buddy had a set of 18s on his 4 seater when he got it. it rode like shit with 32" tires.. not enough sidewall.
I wouldn’t go bigger than 16 or 17” maximum on wheels for the same reason, those 20” size wheels are mostly used for mud tires with chevron pattern like tractors, those who play in deep mud love them.
yep 5x4.5 - very common size - not sure about 17 inch though. 37 on 14 or 15 will be cumbersome and heavy I imagine though.....17 inch rim seems like a good size for that tire, looks like plenty of sidewall.
1 - 14 of 14 Posts
