1 - 8 of 8 Posts
Getting everything to do the 1000 swap can I just use the trans also then I would have no clutching issues
Yep, we make Z1 kits for both and I can mix and match. I guess that is what you are asking?
Yeah the 1000 motor I purchased came with everything from the pedals harness motor tranny and all the clutching just wanted to make sure there wasn't any geaing changes between the 2 cause for now I still have the stock 900 front diff that eventually I'm goin to swap out and put the 1000 diff in
Your not making any sense at all! Only you know which 1000cc motor you have... Are you trying to put a RZR1000 motor and trans in a RZR900? Are you trying to put a RX1/Apex motor bolted to a RZR 1000 trans into your 900? Are you trying to put a Z1 motor into your RZR900? The more specific you can be, the better answers you’ll get...
Seems like you are putting a drive by wire XP1000 motor in your 900, and you are wondering if the 900 trans will work? I dont know if they will.
EDIT and now I see this thread was resurrected :(
Discussion Starter · #6 ·
Yeah that’s what I did a whole xp 1000 swap harness pedals tranny everything fairly simple everything is running good
1 - 8 of 8 Posts
