Can I use stock front rims, in the front and and back with 30x10 14 tires?
8.8K views 8 replies 4 participants last post by  Basicbob
I had the idea that I could pick up a coupe stock front rims and use them in the rear and put 30x10x14 Terrabite's all around. But now I'm thinking they might be too narrow of a rim for a 10" wide tire.
Stock wheel is 14x6.
What do you all think?
#8 · (Edited)
You can't use the rears on the front on XP1000 or XPT. The 8"(6.5+1.5) will rub. But a miss matched set of fronts with rears in back same tire is still OK. The slightly smaller diameter rear (if it even is) is not enough to cause problems with the front differential. I have two cars with fronts all around 30" Mongrels. Love it. If you do this the rear axle is 1/2" shorter on each side than the front. Don't worry about it. It is designed that way to help turning and tracking. The 8" rear rim center is closer to the midline of the car to give this effect too even though the edge of the front and rear tires line up. Don't put in a spacer. Too much stress on rear axle.
