Just curious...
Thinking about picking up a cam tensioner soon... What's involved with the install?
Remove the stock hydraulic tensioner and screw in the mechanical tensioner...Just curious...
I remove the valve cover to watch how much tension I apply as I screw it in...
The Only reason I'am looking to buy one, is to stop the cold start rattle, other then that I'am having no problems with the factory one. I may just leave mine alone, polaris doesn't think the cold start rattle is a problem, it's normal they say. Lol
"Are you sure the 1356 doesn't have an anti drain back valve?"
Yes.
It's a simple matter to prove this to yourself. Go to NAPA and have the counter person pull each oil filter from shelf stock -- Unbox and inspect. It will then be crystal clear which does and which does not have the anti drain back valve.
The WIX is the same filter -- It just has a 5 in front of the filter number.
:ride:
