Build or buy the right RZR S for Mudding ??
I am going to purchase a new RZR of some sort . I ride mostly trail ,lots of mud and the odd fast paced fire road. Width can be an issue some times ,however ground clearance concerns me more as does reliability and durability.
I am considering two options:
#1 Buy a 011 eps non s and add the SATV + 4 a arm kit and some decent shocks with the tougher Rhino axles and a lift . Either way i plan to run 30 inch tires with this set up i could be around 57 inches wide (nice) with lots of clearance and a decent ride . Also i think alot more durable set up. As a bonus i also have power steering and do not need off set rims which are hard on the whole hub/front end ,etc
#2 Buy a RZR s and add a lift and rhino axles , I would have to find 14 inch rims with stock offset as i do not wish to go any wider (850 XP ? ) This would put me at around 60 " wide , without power steering . So i know the EPS rzr would be more nimble and a little narrower.
Doing a rough guesstimate the price works out about the same more or less.
Has any one on here used the PLUS 4 kit with the boxed a arms (not the plus 5 rzr s kit ) if so what are your thoughts on it .
Any input would certainly help......
