This high quality bus bar accessory kit is all that’s needed to install light bars, fans, radios, and any other switched accessories in your 2017-Current Polaris RZR and General. This kit features:
30 Amp Capacity
Relay Switched Power
Fused
Lighted Rocker Switch Ready
Ignition Switch Controlled ( No dead battery if you accidentally leave an accessory on )
Lightning Fast Installation of Accessories
Here is how simple it is to install an accessory on your machine when using this kit.
Connect RED and BLACK wires to your accessory. RED is 12V+ and BLACK is ground.
Plug in YELLOW wire to the center(common) terminal of the rocker switch. Plug in BLUE wire to the rocker switch light ground if equipped. Plug in RED wire to the normally open contact of the rocker switch
Plug in the main harness connector into the bus bar.
Fasten the relay with a screw or zip tie.
Install a mini blade fuse of the current rating of your accessory.
Done!
Includes:
Complete Switch Harness
Relay
https://otbpowersports.com/product/polaris-bus-bar-accessory-kit/
