Ok I thought I would start a thread about mods that need to be done in order to make these Rzr's more bulletproof. From what I have read so far there is some weak links that could be improved upon. This will also vary a little based on what year your Rzr is.
First of all I had a centre bearing seize up on my new to me 2011 Rzr XP so I am installing a low profile pillow block with a NSK greasable bearing. While I have the driveshaft out I am having it trued and balanced and installing all new spicer 5-170x greasable ujoints.
I also have a little play in the front a-arm bushings and ball joints so I ordered today a set of Super Dave's front a-arm bushing kits along with 4 new steel ball joints with grease fittings also from Super Dave's.
I also ordered as spares 2 new pivot works wheel bearings to have on hand even though mine seem OK for now as I have 1700km on this thing.
I have installed outer wears on the intake covers for both the engine and clutches.
I am also considering ordering the Holz motor mounts just not sure if this is necessary yet. Any input on this would be appreciated.
That's all for now unless somebody can pass on any more must have bullet proofing mods/tricks.
