1 - 13 of 13 Posts
Dan and Christy
I was working on my RZR last weekend and when I pulled the tab to move the steering wheel the tab did not 're-engage'. The steering wheel will not lock in position now. Does anyone have any suggestions on fixing this or do I just need to replace the strut assembly? Thanks for your help guys.
The steering adjustment is a pita. Mine is always acting up on me I can usually take it apart and after messing with it for a while It will start working again. But its not very handy to tinker with while out on the trail trying to ride.
I found that if you get the shock-like device removed. you will find a small rod in the center of the shaft. Place it vertically and dribble wd-40 or silicone on the rod. After awhile grab it with a vice grip and easily rotate it around and back until it turns freely. This is what freed mine and it has worked fine since,
John
John
+1.......
The Beast
Mine stopped working, tried to free it up, it then started leaking oil from the button. Replaced with a rode. Then purchased one from Babbittsonline.com for $66.00.
1 - 13 of 13 Posts
