1 - 6 of 6 Posts
If you are like us you get a little aggressive when driving and sometimes stock parts fail. One issue we kept running into was breaking stock plastic seat bases. When one of these plastic bases breaks it allows the seat to move around in the car with only the seat belt holding you and the seat in the car. This became a huge issue when racing where stopping was not an option. DragonFire has got the solution with our new Aluminum Seat Base. Made to exact dimensions and utilizing stock hardware this is a simple swap from OEM. The best part is not only the strength added but also the retention of stock function with your stock quick release clip. Put this issue to bed once and for all with the DragonFire Aluminum Seat Base.
More Info: RZR Aluminum Seat Base
Yes that was a concern when we made these, we didn't want anything solid directly below the driver or passenger. We are all lucky enough to go out and beat on the products we sell and speaking from experience bottoming out on the seat base is no fun!
1 - 6 of 6 Posts
