I recently acquired a 2011 800s from my dad. He never used it much (it has 32hrs and a 120 miles on it
) and I've been going through the process of going over everything. He always ran AV gas in it. So far I've done some basic stuff like change the filter and change the oil. The tires are the original tires, probably 12 years old and need to be replaced. It has aftermarket Fox 2.0 shocks. So my questions are, if I replace the stock wheels with 14's with a 5+2 offset will the width be similar to stock? If they are 5+2 all around will the fronts end up wider than the rears? If so will that affect handling or is it just aesthetic? Don't want to run spacers. Will 28's work without changing up anything? Would I be better off sticking with the 12's? I've been reading a lot and I just can't find a straight answer to this setup. Anything else I should take a look at while bringing this RZR back to life?
