21 - 33 of 33 Posts
I can't find any joe gibbs oil here in canada but I did find a break in oil made by royal purple but it is a 10w30 oil. Anyone know if that would be fine ?
Performance improvements in barrie, on is closes dealer to you. Royal purple 10w30 will be a little thin and you would be better off with the polaris stuff that comes stock in the machine then using it.
Manual says 25 hrs for first oil change.
I've had a few rzr's over the years, 2-RZR S, 2-XP900's, and now my 1000. I always break them in a little on the aggressive side, but not stupid. always run through a few good heat cycles and then a few short wide open blast and always make sure my motor is warmed up before driving hard. But back to the oil issue, just use the factory oil, I always change it early, especially the first oil change (around 15 hrs) I think 25 is too long for the first change, unless maybe your never gonna run it over 4000 rpm's...lol. Polaris has obviously built a good product, some of you hard core racers might think otherwise, but for most consumers the 1000 is all the car anyone will need or use. Polaris does not want you to blow up their motor, and they have the technology and money to make their oil as good as it needs to be, or to use whatever they think is the best oil for this motor. Everyone has a favorite oil, and as long as it's a good oil I'm sure it will be fine, I use Mobil-1 in my Harley's, my performance boat and all my vehicles, and if I couldn't find Polaris oil I would use it in the XP also. The big picture is, polaris wants their motors to last, it's good for business...lol.
Honestly don't see anything in those engines what need to be break in.
And they will not fill the new engines with synthetic oil, if some break in period is needed. IMO
milos
What gets confusing is when Polaris says to change the break in engine oil at 25 hours or 1 month?? So if I only put 2 hours on the engine and let it sit for the remainder of the first month, I should change the oil with just 2 hours on it??
LOL exactly! Mine is 3 months old but has also only been ridden 4 or 5 days. The first month I was on vacation, guess just having it sitting in my garage must have broken in the motor! I'm going by hours or miles instead.
I have heard everything now.
Change oil immediately,
Wait longer than suggested break in period because they are not all breaking in fully,
Run the break in period to be safe then get rid of that polaris oil.
This is what alba was suggesting and I think a few others have agreed this is a good way to go. Polaris RZR oil change kit (Get that Polaris oil out of your RZR).
I just bought some but have not changed the factory oil yet. I'll probably do it after this weeknds ride which will put me around the suggested break-in period hours wise. I believe alba says this stuff is thicker than polaris oil yet it is only rated as a 10-40?
I'm a little worried about warranty, dealer told me I must have them do the first service, but I'm not sure that is legal and will probably do it myself anyways. Then they told me after that I can do it myself but I need to save receipts. Well I get my oil under the table from a friend of a friend that works for maxima, so there are no receipts for the oil (just the filter).
Any suggestions?
All oils must meet a specific viscosity range for them to be classified as a certain weight oil. Some oils maybe on the thinner end of that range and others maybe be on the higher end. However, IMO, that does not matter as much as how much the oil will shear during use.
While I have no hard proof, I have read more than once that the polaris 40 and 50 weight oils( manufactured by Lubrication technologies in MN) shears pretty fast.
I don't believe that any Poo engine will suffer failure while using polaris oil with proper OCI, but I do believe there is much better oils on the market for less $$$ than the polaris oil.
I'm not saying don't use polaris oil, you have to use whatever makes you sleep well at night.
Also, if you are unsure of what is the best way to break in an engine, follow the engine builders advice. On brand new RZR's that would be the owners manual. Many people have their own opinions on how to break in an engine, but how do you know they are right?
P.s. The dealer or manufacturer cannot force you to pay them for service. That's illegal.
21 - 33 of 33 Posts
