1 - 4 of 4 Posts
Has anyone replaced the brake switch on an 800?
Does it just screw in and out?
Does the brake fluid leak out when you make the change?
If you don't have a service manual you should get one. Saves so much time and money. I'll look it up on mine.
I do have a SM. This it doesn't same much about replacing the switch. I used it to determine it was bad. Thanks.
Cool but to answer your question yes fluid will leak out and you'll have to bleed the brakes. Good video on YouTube for the repair.
1 - 4 of 4 Posts
