1 - 5 of 5 Posts
Help?? So I'm wiring in 5150-187 whips as well as installing a switch pro panel. The only place I touched (what I thougt) was the brake light wiring was attaching the brake (white) wire on the whips to the power wire coming off the brakes. As it turns out, I initially hooked it to the tail light hot wire (on the small light on top of brake lights). I disconnected it once I realized what I did but it really shouldn't matter...both would put off the same amount of current correct?
So what's happening is my brake lights remain on AND It will start without hitting the brake? I can disconnect the electrical plug on the master cylinder and it seems to reset itself and it works correctly for a very short period of time, but inevitably sooner or later when you hit the brakes, they stay on.
Any thoughts on what is going on here? Also seems as if it may have torched the bluetooth module on the whips as my phone isn't picking up any signal from it.
I love wiring. :)
2020 900 Trail Fox Edition
Wires tend to see the same voltage but not the same amount of current depending on the size of the wire. I was under the impression those lights were best wired to the battery thru a switch and relay? I would also take a look and ensure your polarity is correct with that said LEDs don't tend to work with reverse polarity. I think I would undo what you did test the brake system for normal light operation and rewire the whips. I'm sure one of the electrical experts on the forum will have a much better answer. JMHO
The brake lights are a switched ground, not a switched positive. It sounds like however you have the whips wired, you are back feeding voltage to the brake pressure switch. I would also suggest you disconnect the whip wiring and test everything for proper function and go from there.
Man…I’m getting senile. Forgot I posted this and posted it again, geeez. So the war here rages on. I didnt use the whips wiring harness per the folks at Switch Pros and 5150. Wired the hot wired directly to the switch pros #1 switch and set up a ground bus bar for all accessory grounds wired directly to battery neg. There shouldn’t be any cross pollination with the brake system wiring other than that white wire on the 5150 bluetooth harness that is supposed to piggyback off of a brake trigger wire.
I did disconnect that for a bit and the issue still persisted.
On another note, when the brake lights go wanky I can also start the car without the brake pedal pressed. In addition, when I unplug the harness on the master cylinder and plug it back in - the issue fixes itself for a short time. It all works perfectly, whips light red on brake press, car wont start without brake pedal pressed and brake lights are normal. Then it randomly reverts.
1 - 5 of 5 Posts
