I have a 2021 Turbo S4 and I replaced the wastegate with a dyno jet one and I am receiving a “Boost pressure sensor code” it says Signal Out Of Range. Anyone know what I can do to fix this? I replaced the boost sensor but no luck.
Did you change the tune for the wastegate actuator? The DynoJet actuator has a higher crack pressure, so you have to have a tune to model that. You're probably overboosting by a lot.
