1 - 12 of 12 Posts
Racertech's brace bolts in directly above the front differential connecting the frame at the points the upper arm is normally relied on to hold together. This brace allows the arms to do their job of pivoting like they should and takes tons of stress off the chassis since it holds the frame together much better. From the factory, the upper A-arms are required to hold this section of the chassis together when bolted on. A general rule of thumb in any type of chassis building is to never require a suspension component to double as a structural asset to the design. This plate fixes this. There a lot of other companies making this same product already but ours are stronger. Notice the bent edges and dimple died holes added in to substantially increase rigidity while remaining light weight. NOTE: if you already have a winch mounting plate above your front differential there is no need to use this part.
Polaris RZR Front Lower Chassis Brace - $69
I bought this Racer Tech Support and it fits and bolts in without any hassle...
The way it boxes in the front differential it has to be stronger... Very nice powder coating too...:):):)
Yep Racertech makes a good product.
Can you check with Racertech and make sure this will work on an '11. If you could PM please then you get an answer. Might not check back here for a bit.
So I got 2013 xp and have plans for a winch. So a winch mounting plate for the xp should pretty much do the same thing????
1 - 12 of 12 Posts
