1 - 4 of 4 Posts
· Registered
2017 XP4 1000, 800 miles, when I hit 50 mph the power steering light turns and starts bogging almost like a governor and it decelerates slow almost like it’s stuck in gear. Sometimes it stalls in gear also and hard to shift it too park. I already checked the spider nut, replaced belt, checked the gear selector sensor, checked the battery, spark plugs,checked most of the obvious things that I have read here. Any other suggestions would be appreciated.
Thanks
· Registered
Discussion Starter · #4 ·
I have not, I will take a look at it. But with 50 hours I wouldn’t think it would need one. But you never know so I’ll check it out. Thanks
Problem solved, it was the clutch. More specifically the rollers and arms. I didn’t do it myself a shop did so that’s all the info I have.
1 - 4 of 4 Posts
