BMP RZR 1000 Exhaust & Program = 18hp
158K views 638 replies 97 participants last post by  jackstrx
We have some excellent things going on for your RZR 1000 owners! We all know very few exhausts make much horsepower. On the 2014 models, our exhaust made 7-8hp at the crank. That was with a TON of R&D time into our header.
The biggest issue most companies have is dealing with the safety parameters built into the stock ECU. Since these new units are all throttle by wire, it's very easy for the ecu to limit power when it thinks something isn't right. For gaining power, this is a nightmare.
We developed an ECU tune which locks the throttle by wire and gets rid of many of those pesky things that would pull back the throttle such as overspin and more. We then ran our power commander 5 on top of that which worked well.
We now have been working with the Bully Dog GT. As much as we love power commanders, this unit goes above and beyond. It allows a full reflash of the ECU so we can change so many more parameters. We worked, and will continue to work with this unit on the dyno to develop more programs for big bores & other modifications.
The gains we have seen are incredible! We were able to crank out 128 horsepower with just exhaust and this program. The 2015 models with our system (deletes the cat and o2 sensor) need this program to run. The bigger cam 2015 motor has not been dyno'ed yet, but we have field tested so programs are ready to go. We estimate over 130hp with the 2015 models.
The biggest reason we are able to gain so much more horsepower is revving the motor higher while optimizing fuel and timing in this area. Most others cannot do this because the throttle by wire has it's own RPM limiter, as well as the hard ignition limiter. When we program the ECU with the Bully Dog GT, the rev limit is at 9000rpm with no soft TBW limiter. Clutch for 8600-8750rpm and the RZR 1000 turns into a monster! Acceleration is just as big as top end pull.
So what is the Bully Dog GT? This is from the manufacturer of the same truck tuners many people use. This can do many of the same features such as data log, read trouble codes, re-set trouble codes, and act as a full gauge viewing all sensors available on the 1000. This is an incredible device that is extremely easy to install and use.
We have a ton of information on this located on our website. The best deal is the Stage 1 Bolt-On Performer Kit. This comes with everything you'll need. See the link below:
RZR 1000 - Polaris - UTV
We look forward to any questions you may have!
-Mike
Our level 1 tune is an optimized stock tune. This tune is loaded into all of the Bully Dog GT units we sell for $699.95. This has all the throttle by wire locked, raised rev limit (9000), raised speed limit, and optimized timing/fuel curve. Stock timing really falls off at 7700-up. We straightened things out and make 3-4 more peak power that will rev out to 8500-8600rpm. Our dyno tech is on some projects now, but he's going to find the graph for that level 1 tune. He just has about 300 runs to go through.
Unfortunately, you do not have any ability to adjust this unit. Bully Dog does not release the software to make adjustments to the public. You should not need to make adjustments if you are running a stock machine, or have our modifications (or other mods very similar).
We can have you data log and send us the file, then help you create a custom tune if necessary. This will cost $100 per custom tune. If you have a power commander map, we can also translate that into a custom map, but again this is a $100 custom tune fee.
You can still add a power commander or other fuel controller to your unit and make fuel/timing changes that way. If you click the link below you can see all the tunes that we will have available. These should cover just about everyone.
Bully Dog Powersports GT Tuner for RZR 1000 - RZR 1000 - Polaris - UTV
Thank you,
You would just want our Bully Dog tuner with the base level 1 (stock optimized) tune. This will lock the throttle by wire, give you more RPM, and 3-4hp peak. Acceleration is the biggest key because your machine will not close the throttle under wheel spin which always happens in the holeshot.
What's the cost of stage one.
$1995 for the stage 1 kit.
So $699 for the tuner + $50 for the tune from BMP. Looks like the tuner works on a few other vehicles and generally sells for $450 or so just doing a quick search. What's the difference in the cost for the BMP XP 1000 tuner? I might be missing something....
What your seeing is a base tuner that will do nothing but data log and check engine codes. No actual tune would be installed in that unit for $450. With us, your paying for the tuner, plus the tune and everything setup specifically for your RZR 1000. The companies who sell that for $450 is under retail also. What we are doing is highly technical and has taken many hours to develop. Many customers were buying ECU's outright from us with a program that was not even as good as this one (didn't have optimized fuel/timing) for $850 outright. We thought saving those people $150 while giving them data logging, a gauge, and on board diagnostics was a great deal!
It's amazing to me that less than two years ago (pretty much) everybody was saying that you couldn't simply 'bolt on' anything and expect much in terms of HP gains.
Today we're apparently at 21 HP with what looks to be an attractive/informative controller and a clutch kit included for 2K.
That's a big jump and change of somewhat 'consensus' opinion for a 107 HP (2014) machine that a lot of folks figured Polaris had designed pretty darn well before even the HO version arrived.
I've always understood Bikeman to have a great reputation and can remember them positively helping people out on various forums 'back in the day' on other machines as well.
Thanks for the kind words! We work hard to develop things that actually produce power. These new units are just harder than most. Just wait until you see what just out program does on a new 900 RZR!
I'm very interested in this package but I have a couple questions. Do you have any pictures of your exhausts mounted, I see there are two options for coatings but I would like to know which would look better on the machine? Lastly, do you have any comparison dyno charts that show below 7000rpm, I do a lot of tight twisty trail riding and often times like to get up to speed from a much lower rpm, just curious?
Looks like a fantastic deal no matter what though!
#15 ·
See the video link below. This shows the exhaust mounted up. I actually have a note to get some images of it mounted... I just need to clean up our RZR here and get it done. Unfortunately, I don't have any images of ceramic chrome on the machine at this time. Both look great, just depends on your preference! Ceramic chrome does hold heat inside the exhaust better. The black is a very durable coating, but does allow more heat to pass through it. This is not a problem on the 1000, but more just FYI.
On this type of dyno(or just about any dyno), you can't display low end power very consistently. The dyno puts such a load on the motor it sort of struggles to pull through it. This makes the graph jump around and not display real gains. We can tell by ear, and what the dyno tells us how the tuning is, but to display the actual hp graph is almost useless at that RPM. I can assure you we gain big from down low to up high.
#9 · (Edited)
We do not have DB readings at this time. We are waiting until our quiet caps are finished before testing.
As you can see in any of the product pages, the exhaust can use 2 of the stock 1000 RZR spark arrestors. The optional quiet cap will cap off one of the two outlets quieting the exhaust even further than running 2 spark arrestors.
Sound options:
Wide open no caps or spark arrestors = Loud, but not horribly obnoxious
1 spark arrestor (not sure why you'd just run one... but it's an option)
2 spark arrestors = medium tone
1 spark arrestor, 1 quiet cap = quieter with db's just above stock
This looks like a great package! We are going racing this year, and will definitely be in touch. Adding the AirXtreme kit sure is tempting too.
It's reassuring to see that you do your engine development work on an engine dyno. I've never been comfortable with engine parts that were built using a chassis dyno. I've seen too many cases where a chassis dyno cannot properly load the engine to produce reliable results, especially when tuning EFI systems.
I also like that you are using the Bully Dog tuner. We were already looking at the Bully Dog tuner for all of it's extra capabilities that have not previously been available to the Powersports market. This is a really nice package.
#20 ·
Quote: Originally Posted by Sjenko View Post
Hi, Im from the Uk and have a 2015 XP 1000. I race short course in the British SXS Championships and im looking at gaining a little extra acceleration. What do you recommend??
Thanks
PS, We are not allowed any internal mods. Just exhaust, fuel controllers/ecu and air intake.
Im a bit confused? Would I not need the full stage one kit on my 2015 XP 1000 then?
Thanks
#21 ·
When I said we are not allowed internal mods, I meant inside the engine, like big bore, porting, cams etc. Anything that bolts on is allowed. like Exhausts, intakes,fuel controllers.
Im currently running stock clutch with a NON EBS Helix with 26/11/14(rear) SUNF Tyres(like maxxis Ceros)
thanks
#29 ·
Horsepower at the tires depends on clutching, tires... ect. It's so inconsistent on these models. We only do this the right way and dyno engine horsepower, then clutch for the target RPM.
Horsepower with this tune is increased, but the biggest increase is the locked TWB and no soft limiter up top. The machine is just so responsive and has a quicker feel. 100% go with the bully dog. The ECU tune was a great thing, but didn't have the modified timing and fuel curve. The factory timing curve is honestly a mess. Has drops and all sorts of strange things. We smooth things out for a much better running machine. Plus being able to data log and check any engine codes on the fly is huge. Also a full set of gauges. Its a no brainer.
#30 ·
Is the bully dog plug and play? You send it to me with the tune, I plug it in, flash the computer and it's a done deal? I just got my rzr and this sounds like something I'd like to do after I get some miles on it and make sure there are no mfg defects before I take a chance on voiding warranty. Also say I wanted to return it to stock, is it as simple as flashing the stock tune back in it and removing the clutch and exhaust?
#31 ·
Yes the unit is completely plug and play. We send it to you with the tune specific to your ECU serial #, then you plug it in, program and ride! Like we said before, it's a great tool to mount and view as a gauge with many capabilities. If your the person who doesn't want others knowing your tuned, you can remove the unit after programming.
Returning to stock is exactly as you described.
#36 ·
We have not tested with the cap yet, but we have done testing in the past and just by knowing muffler flow characteristics on this motor it won't be much. You'll probably be down 1-2hp with the cap and spark arrestor. Basically, you'll be flowing the same amount of air as stock (which really isn't horrible to begin with). We have tested these setups with a stock muffler and we lost about 2-3hp. However, our internal muffler design is more free flowing to begin with so that will be slightly better than the stock muffler.
Sounds fantastic. Anyone running this that can provide some consumer feedback? Specifically on 2015 RZR.
Any dyno sheets for the 2015 yet?
I e-mailed a customer who has one race on this kit so far. He should reply soon. From what he's told me, its night and day difference!
Right now we are dyno'ing big bore/big valve setups. Once we are done we will return the motor to stock and install the 2015 cams to double check the program and see horsepower. We should have results by next week.
#37 · (Edited)
I have this set up on my 2015 RZR 1K 2 seater and holy crap!! It’s not too often you can feel a performance gain from just an exhaust and programmer but with this set up you can feel it. Plus the noise of the exhaust kicks ass. Gives you that throaty loape under idle and really lets the 1K sing at W.O.T. I mounted my Bully dog in the waterproof compartment under the dash because I didn’t want people to mess with it and change some setting because with this set up you can access a lot of the internals of the RZR. I just let Bikeman set mine up with a tune and plug in the SD Card and it is ready to rip. Feel free to ask me any questions about this set up and I am hoping to up load a sound clip soon.
#38 ·
I have a 2015 1000 and we ride dunes at sea level and over 10k in the mountains. Would I need 2 tunes without the O2 hooked up? Also want would the price be without the clutch kit. I just purchased one a few months ago? Last question what are your thoughts on the air filter that comes with the kit. I here good and bad about an oiled filter?
#39 ·
The o2 system on the 2015's is only for idle and cruising speeds. This is how they get past emissions standards. When you get on the throttle your machine goes into open loop (not using the sensor at all).
That being said, your EFI system still knows how to compensate for altitude without the o2, just like the 2014's did.
Drew who posted above is a good example. He lives in Flagstaff AZ at 7000ft, and was racing in havasu a few weeks ago which is low alt. Program is working good at both ranges. Clutching should be all that needs to be changed when changing altitude.
We have always ran an oiled filter without any issues. The oil really helps to trap dust from entering the engine. However, I know some of the better paper filters trap quite a bit also. Certainly you can buy the kit and use any other filter you'd like, or buy the parts individually, not purchasing the filter.
