1 - 11 of 11 Posts
I got a couple of sets of these at Harbor Freight. They have worked great for me. I was going to get the plier type until I found these.
I have the same orange ones from amazon, zero complaints.
Bought these on Amazon to stop coolant from draining out when swapping out the IC.
Anyone have experience or thoughts?
I am a professional auto mechanic. I use those. Buy two sets. They work very well, but only if using the correct size for the hose you are clamping. They will leak a little, if you handle any hoses once they are clamped. Other than that, they are great.
Discussion Starter · #8 ·
I assume that you are saying that I'll need 2 of the same size - one for each line to the IC?
Yes. One for each line. If both lines are the same size, which is pretty common. You will find the middle size perfect, the large too big, and the small too small.
I never had big success with those plastic ones, I just slide rubber hoses on both side of Wise Grip needle pliers and work perfect every time.
1 - 11 of 11 Posts
