Is it necessary to remove the air bleed bolt/ plug above the header to remove the air after flushing or replacing coolant? Doesn't the coolant eventually bleed out air after running the engine?
We always bleed at the head. The head will trap air in there that just seems to never bleed itself. The tiniest bit of air in there will overheat you in a hurry.
I bought the Harbor Freight coolant fill tool. Works just fine. I also put mine up on two cement blocks (per side) first. I'm told either remove the need for dealing with the difficult to get to bleed valve.
I've also found elevating the front while filling helps like stated above. Also agree that bleeding at the head is a P.I.T.A. but is most affective. Be happy it's not a turbo, the heat shields make it much worse.
Related Threads
Polaris RZR Forum - RZR Forums.net
posts
3.2M
members
152K
Since
2007
A forum dedicated to Polaris RZR enthusiasts! A great place to find rides, meet people, and exchange ideas / parts/ rzrs!
