1 - 5 of 5 Posts
The most radical 570 MT. Having gear reduction in your portals can you use your high & low ranges much as normal?
And are you running beefed axles?
Such a beast - I hope it works as well as it looks.
Thanks! I run cheap axles from Ebay and amazon (sixity and I dont remember what the others are). I still use high and low like normal. Trail riding speeds are usually under 20-25 mph so I run in low just because. When I'm driving around town or main dirt roads back and forth to camp then I run high.
The portal reduction is awesome as my tires weigh 51lbs each before the wheel is added. I can still cruise and play which is nice.
1 - 5 of 5 Posts
