What is the best way to cut the dash for a rocker switch install? Dremel tool or drill small hole and try a small blade?
J to the B 4,893 posts · Joined 2009 Add to quote Only show this user #2 · Feb 11, 2010 I'd say either is fine. I drilled a hole and used a small dry wall saw.
TRXR 2,114 posts · Joined 2009 Add to quote Only show this user #3 · Feb 11, 2010 Dremel...with an exacto knife to fine tune the hole. Remember...always start small and work your way up to the desired size hole.
Slated4Greatness 156 posts · Joined 2009 Add to quote Only show this user #4 · Feb 11, 2010 Rotozip...
flip 184 posts · Joined 2009 Add to quote Only show this user #5 · Feb 11, 2010 I used masking tape and drew the outline of what I wanted to remove. You have one shot at it. Less is best. Take your time. I used a high speed air tool with a small cutting bit. Attachments RzR 010.jpg 266.1 KB Views: 1,340
8ball_99 4,651 posts · Joined 2009 Add to quote Only show this user #6 · Feb 11, 2010 Dremel then a utility knife to cut the corners.. The plastic is very easy to cut with a knife..
akdredger Discussion starter 88 posts · Joined 2010 Add to quote Only show this user #7 · Feb 11, 2010 Thanks Guys for the info, the tape and drawing the outline will help.
Aharzr 778 posts · Joined 2008 Add to quote Only show this user #8 · Feb 12, 2010 just be sure you make that hole exact, on the tight side is better. It don't take much to overcut and your switches will flop around.
motosx 434 posts · Joined 2008 Add to quote Only show this user #9 · Feb 16, 2010 I used a utility knife heated with sm propane torch took minutes and no mess. Cuts like butter.
akdredger Discussion starter 88 posts · Joined 2010 Add to quote Only show this user #10 · Feb 16, 2010 That sounds like an easy way. Will try this weekend, 3 switches to install, a - arm guards, lighted whip, and lift kit going in. Ah this is as much fun as modifying my truck, but a whole lot less expensive!
TRXR 2,114 posts · Joined 2009 Add to quote Only show this user #11 · Feb 16, 2010 Fun yes....less expensive, IDK about that. lol
mack90 594 posts · Joined 2009 Add to quote Only show this user #13 · Feb 16, 2010 rotozip was the best for me
