best place for water temp sending unit?
11K views 30 replies 16 participants last post by  kimmer
where is the best place to splice in an aluminum tee and sending probe?
upper hose or lower hose?
closer to motor or radiator?
I AM WAITING FOR MINE FROM UTV CRAP, WHEN I ORDERED IT THEY TOLD ME YOU WANT IT AFTER RADIATER IN THE FLOW OF WATER THAT HAS ALREADY BEEN COOLED BEFORE IT GOES BACK INTO THE MOTOR FOR THE BEST READING.
I installed mine in the purge hole.
This is an interesting topic because i was thinking you would want it to be on the tube coming from the motor to the radiator because it would give you a more acurate reading of what the temp of the motor was verses the already cooled water coming from the radiator. I dont know though that was just my logic when thinking about it interested what others have to say
MY UNDERSTANDING OF IT IS THAT THE WATER THAT'S BEING PUSHED INTO THE MOTOR IS MORE ACURATE BECAUSE IT IS TELLING YOU WHAT TEMP YOUR COOLANT AS IT IT ENTER'S MOTOR AND AT THE SAME TIME IS TELLING YOU HOW COOL/HOT YOUR COOLING SYSTEM CAN COOL. I JUST ORDERED A KIT A COUPLE OF DAYS AGO AND ASKED UTV CRAP ABOUT LOCATION OF SENDING UNIT AND THATS WHERE THEY SAID TO PUT IT.
i can tell you in automotive use its at or just befor the thermostat and is water leaving the eng also they install them in the block this way you monitor the actual eng temp... not water that has been cooled in racing this could be the diffrance of a blown head gaskit vs knowing how your cooling system works.... most eng damage starts at about 250 deg and if your moitor the coolant coming out of the radiator it could depending on your radiator be 75 deg or more cooler giving you a false reading .... yes it would be nice to see both but befor is more important a reading...
Sounds Like You Know Alot More Than I On The Subject, I'll Make Sure I Ask Again Before I Install Mine. Maybe A Miscomunication W/ Utv Crap.
I would say the best way would to screw the sendor for the light and put the sendor for the gauge in its place. If the thermostat sticks closed you will never know the temp. LIGHTS SUCK unless you use them to see where your going. LOL
id install the gauge in the tee and mount the tee as close to the thermostat as possable it would be close enought now the next question is what does polaris run the rzr at? anyone know what temp the thermostat is?... add about 12 deg to that and thats your avg running temp.... but i would use about 230 as a start to worry temp...
so, they can tap your old one and sell it, it's a exchange.
They have to tap threads in it.
#20 ·
put it in the purge hole.. it's aluminum, even if the thermostat sticks it will let you know if it's hot.. if it gets real hot the dash puts on a real nice light show to let you know about it..
you guys are over analyzing this.. it's a temp sensor..
#21 ·
Then You Have To Take It Off Every Time To Bleed Cooling System ?
#22 ·
nope, you just loosten it.. it still works the same as the bleed screw..
#23 ·
#24 ·
unless your thermostat is stuck, then it's a big deal
You will want the upper hose between the thermostat and the radiator. I have been riding with one for years on all my quads as we ride only mud. Your normal operating temp will fluctuate between 180 and 210. Once you hit over 210...stop riding as you are overheating.
#29 ·
I just put a gauge in mine today, and it also seems to be running about 140-150ish..........it is cool outside, about 13 degrees C...........I rode 10+ miles, lots of it at 10mph or so in tall grass and water and stuff, never came over 160......what temp does the fan switch on at, as it came on when I pulled into the garage and stopped.....?
#30 ·
On my 700 and 800 Sportsmans I installed the sensor in the thermostat housing (at the bleed screw). You definitely want the sensor as close as possible to the where the coolant is leaving the motor. There isnt much point in having a coolant temp gauge reading coolant that has already passed through the radiator. I also has saw guys place a "T" fitting in the hose leaving the thermostat. Thats seems to be just as accurate as using the thermostat bleed screw. Not sure what gauge Im going to use in our RZR we have ordered. Do you guys have any pics of where you mounted your gauge in the dash?????
