1 - 3 of 3 Posts
· Registered
ok guys i'm fairly new here but would like to know whats the best aftermarket airbox or whats everyone doing for cleaner air i own a 2010 razr le and this stock setup is crap, put a uni in but probably going to snorkle as well, a buddy has done his and his filter doesn't get as dirty
· Registered
I like the Dragonfire (BTI) semi-sealed for dust...sealed for water. A 2" rubber 90 on the round BTI (not the oval used for the stock intake between the seats) part and ABS 90 street will put you dead center for the engine air intake. You will have to open that hole up a bit more than 2 1/2" to get the street up inside the bed assuming you use the make your own snorkel method found on this site.
Eli
· Registered
Snorkeled to the roof using the Artic thunder Kustom snorkel kit. Also running the UMP box with a 6" rubber cap on the end. Completely waterproof and sucks very little dust from way up top. IMO, the stock intake is in one of the worst locations. Right where the dust swirl effect takes place in the cab.
1 - 3 of 3 Posts
