I overshot a corner the other day and hit a ditch sideways pretty bad. Both wheels went flat instantly and my lower A-arm was completely bent but the rest of the components on the front right side seemed fine. I eventually got the wheels pumped back up and the lower A-arm replaced and the unit seemed back to normal just looking at it at least. I took it for a test drive a noticed the front right wheel wobbling a little bit and thought I had bent the rim but I switched the 2 front wheels around and the problem remained on the right so I guess something on the axle is bent. Turning the wheels over with the unit on a jack the drive shaft seems to be pretty straight its only the wobbly right at the end. Could it be just the outer axle that's bent or is it the hub?
The wheel only wobbles a little bit when I ride, do you reckon it will be okay to continue riding while I wait for replacement parts?
The unit is a RS1
The unit is a RS1
