1 - 8 of 8 Posts
Bench is to be delivered 08/16/10. My question is does the center lap belt share mounting bolts with the left & right lap belts ? TS bench with 5pt belts driver & pass. with Y belt in center. :question:
While at the bench seat questions. How in the heck do you remove the seat to check the oil etc if your 4/5 points go through the seat? It looks like it may be a real pain. However I have never done it. I would like to hear from someone who has a bench.
You might want to check your bench to verify that the frame is straight when you get it also. Mine was off by over an inch. They refuse to resolve the issue.
It's a royal pain since the harnesses bolt through the seat slots and the harnesses have to be removed with the bench to access these areas.
I bought a dipstick relocator from factory utv, that way you don't have to take the seat out to check the oil.
1 - 8 of 8 Posts
