1 - 20 of 37 Posts
· Registered
Just want check with STM clutch owners, if by any chance somebody find the different ( better ) belt which can be use with STM clutches in place of 3211130 ? :question:
milos
· Registered
milos
Hello Milos .............
Use only the '09 "S" belt -- -- 3211130.
I'm having no issues with this belt. Although you will notice the lower cogs will have accellerated wear. The sheave angle is maybe 1 degree more severe causing the belt to show wear on the lowest part of the lower cogs.
I do have a slightly different configuration than you have ......... I'm well over 300 grams on the primary and am running both stages. On asphalt I can lift the front end and blacktrack on the primary.
I've no complaints at all with the STM setup.
Dave
· Premium Member
milos
Dave
So far these are the best we have used but managed to waste 2 of them at the hill pretty quick. The next day we let them cool down and they seem to survive.
· Registered
Discussion Starter · #8 ·
milos
Dave
Thanks Dave, no I don't have complaints again this clutch set I really like it, but first belt hold for only 270 miles and I thought maybe somebody come up with different one.
Milos
· Registered
milos
Dave
Thats correct. Heat kills any clutch system and belt.
I have no problem as I've ventelated the CVT cover. I take fresh air that comes down thru the tunnel and blows on both the primary and secondary. I also have an opening to take the belt measurement. I also have 1 1/2" holes around the CVT cover directly over the belt not only for cooling - But to sift out any debris.
Maybe a pic to illustrate ...........
Gott luv the overdrive to .......... 70.8 (GPS) on the Sand at 6487 RPM !! New fuel system and I ran out of fuel to go faster .. .. :rofl3:
:ride:
· Registered
Discussion Starter · #11 ·
I will need to work on cooling too, open cover with some holes like Dave did, but it is any problem, if sand get on clutches ?
milos
· Registered
milos
Hello Milos -- --
The reason I just don't take the CVT cover off altogether is -- I wanted just a bit of protection -- Incase a belt decided to let go. I've partially broken the cordage on a belt -- Not a Polaris belt ..... No problem in using the "S" belt.
What the pic doesn't show are the holes underneath. Being the front driveshaft goes under the CVT and the greaseable spline is directly underneath -- I stayed 4" away from driveshaft centerline. This leaves an 8" solid protection for grease splatter and doesn't get into the CVT.
Any particle of Sand that does get inside -- Is either pulverized or drops out the bottom holes.
I have several thousand miles with this modification. Absolutely no issues to date.
Mine never sees water.
Dave
· Premium Member
Dave
:ride:
I vented my clutch cover a little more than yours and I can put my hand on any clutch part after riding ...
I really like my RAGE VIII STM Primary Clutch & Tuner Secondary Clutch...
Easy to clean, easy to adjust..
I use the belt STM states must be used Polaris part # 3211130
· Registered
Discussion Starter · #14 ·
I copy Sparky design and open my clutch cover for more cooling, but try to help even little more I installed small 4" Spal fan over secondary. Will be probably better to have fan blow on primary, but seat bracket is in the way.
We will see, if this help belt to survive little longer. :ride:
milos
· Registered
Discussion Starter · #16 · (Edited)
Hello Milos -- --
That will greatly help in cooling !!
Butt .......... You made a mistake when you assembled -- Do you see it ??
:ride:
Really don't know, help me ?:question:
Come on Dave, last 20 minutes I stare on pictures to find my mistake. LOL
milos
· Registered
Hello Milos -- --
Here are some hints -- Not so much for your benefit .. Butt - For those who read this thread.
Earlier on in this thread you mentioned that you broke a belt. Heat is the killer as you know.
Another factor is cvt maintance. And - This is the step you skipped. Because of this missed step you're going to generate more heat. Now - with your modification of the cvt cover - The clutch can disipate the extra heat.
The step you skipped ........... Look at your primary -- It's glazed and you've been blacktracking. This is what your sheaves should look like -- --
And this is what your belt should look like .............
By regular cvt maintance - Your clutches will run much cooler and the belt will last much longer. Also take a belt measurement on a regular schedule and one can project cvt maintance and when to replace the belt.
:ride:
· Registered
Discussion Starter · #18 ·
OK I get it, but what you use to get such nice patterns on shaves ? And what you do with a belt? I just wash them with soap and soft scrub.
milos
· ◄►STARS & STRIPES◄►
milos
BlackBart had a whole thread dedicated to the installation of a new belt, all the way down to the cleaning... Here is what he wrote...AGAIN this came from his thread but should help you!!
I Pulled the info from BlackBarts thread on Belts... I will sit back and watch an learn..As Now that I have the 1130 belt and Rage III I can learn something here...THX Guys...
1 - 20 of 37 Posts
