1 - 8 of 8 Posts
Hey Todd,
I see the XP 1000/ 1000 S area on your website, and don't see a belt listed/referenced for the S 1000. Looking at thin for fast trail/dune duty. Am I just not seeing it?
Factory belt on mine is Polaris 3211180.
Thanks.
Copied from Todd's site... haha some misspelled words.
https://www.hunterworks.com/inc/sdetail/56301/96696
HW Belt FAQ's
Made in the USA
This is the New Quiet Thick Dimensioned XP 1000/XP4 14-19 Belt
Includes new Thick White Washer and is Required for Use.
Fits all XP/XP4 models from 2014-2019
Fits 14-19 Highlifter
Firts 16-19 1000S
This Belt is for slower big tire riders ( Read Dimension Article)
Higher strength than the OEM belt
Engineered for toughness and strength
Proprietary contruction
I have been using the thicker belt from Hunter works and I am very satisfied with it.
30" heavy tires, it is good!
Although reading the above post, I am did not realize that the new Thick White Washer was required and I did not receive one with the belt.
Should I be concerned?
The thick white washer in the primary limits the closure of the primary and in return limits the secondary to open to far.
Can you run it without? Yep but your playing with knowing the limits while the thick white washer does that for you...
HW Belt FAQ's
Made in the USA
Firts 16-19 1000S
I did see that, but looking at the STD belts, the S1K isn't listed.
Todd is usually pretty quick to respond. He must finally be tired of talking about belts. :rofl3:
HW Belt FAQ's
Made in the USA
Firts 16-19 1000S
Same belt for XP as S but I could do a better job
https://www.hunterworks.com/inc/sdetail/96685/97482
There is the STD for 1000S
Discussion Starter #8
HW Belt FAQ's
Made in the USA
Firts 16-19 1000S
Thanks, Todd. :ride:
1 - 8 of 8 Posts
