Sliced my right rear side wall so I got an opportunity to measure the offset on both the front & rear wheel. 4 5/8” + 1 3/8” front & 5 5/8” + 1 3/8” rear. 6” front & 7” rear. I tested the rear wheel on the front. Plenty of room. I think you could run rear wheels on the front & front wheels on the rear. I like to rotate my fronts to the back & put new tires on the front. I guess I would like 6 1/2” bead locks with 5 1/8” + 1 3/8” offset! Not likely to find such a size! What is the closest available size? I sure like the 64” width & sharp turning that the Pro XP has.
