I’m about ready to purchase some 35’s for my Pro R 2 seat . Please school me on why I need beadlock wheels or not . Mostly easy desert riding with some easy rock / dry stream bed crawling .
I have owned the Method Bead Grip wheels and did not have a good experience when it comes to changing tires. It is a MFer to get a tire off those rims! I ruined a set of paddle tires trying to get them off those rims. Beware and good luck.I didn't want the pain of bead locks (potential sealing issues, DIY mounting and balancing), so I went to Method 414 Bead Grip. Punctures are a way more common problem than losing a bead, of course. Carry sidewall repair kit and a spare for maximum reliability.
JMHO but the Bead Lock is the way to go for running super low tire pressures with soft sidewall tires or Racing, but Bead Grip is the low maintenance and somewhat lighter option. I never really had trouble with the stock wheels with no locking, so Bead Grip is a step up for retaining the bead.
Bead Grip wheels have been tested in racing, but of course, if I were racing I'd go Bead Lock.
I think this is the right size 414 for the Pro R --size 5X7 bolt pattern 5X4.5 offset spacing 13/4+3
Makes total sense for what you do. I'm not big rock crawler. I only do rock crawling when I have to get where I want to go, LOL. I don't seek it out. Have fun!I run beadlocks on everything, all the time..
The only issue I've ever had with them was altitude related, I went from 8000 feet to 4000 ft and pressures went from 6PSI to 4PSI, but I ran them all week at 4PSI and never had an issue, despite riding pretty gnarly rock crawling trails, to me, being a rock crawling noob anyway.. Don't follow me, you won't make it LOL..
But then I likely run a lot different terrain in CO and UT than you see up in Idaho.. I have for a couple years wanted to explore the trails around Riggins..
Yes, they are a chore to mount and get mounted properly, but I'd rather take the time to do it right, 3 levels of torque increases and made damn sure everything was seating as it should..
Shout out to KMC wheels being the easiest to mount for me.. The tires practically fell on the rim vs other brands I've used..
I haven’t ever seen or heard of these. That is a cool concept and see no reason that these wouldn’t work great.Check out these Assault Hllfire "INNERLOCK" wheels. These things are awesome, and not nearly as popular as they should be. This is not your average bead lock...
Waaaay easier to mount than a standard beadlock with a ring.
Link: https://www.superatv.com/assault-industries-hellfire-wheels-with-innerlock-technology
