Hi,
just install a new set of bandit rzr 570 SERIES 46 GENERATION 2 shock on my 2014 rzr.
did a 60 miles ride during the weekend and test the shock..for the confort there are awesome, big difference with the stock and really happy, night and day..in a straight line it's perfect. but I have a big body roll problem with the rear…
In the turn the rear sag is really big and the front wheel is leaving 2-3 inch the ground even at half throttle..I can't leave it like this as the roll over is for sure at more than half throttle…Actually, I have the front sway bar connected and rear disconnected, cause with the shock we have to disconnect it for the nitro…So what I did is crank up the preload by 1 inch on the rear shock.
After that It was better but nothing compare to my friends rzr 800 evans walker 50"..but he have rear and front sway bar connected.. I'm doing agressive trail riding…and I can't ride agressive with that setting as I have to slow down every turn...
So right now the setting is front preload original(1/2 inch) and rear at maybe 1 and a half inch.
All the option I see right now is :
1- crank up the rear preload more…maybe lot more...
2-Trying to find a way to modify the rear sway bar and reinstall it in the rear…what would be something difficult I think..there is just no place to install it with the shock...
Someone had this problem
