1 - 9 of 9 Posts
Baja Designs – New LP9 8-inch Light 12,000+ Lumens
Announcing the LP9 from Baja Designs. A modern take on our classic 8" La Paz, the LP9 features 9 reflectors plus Integrated Peripheral Technology, making it ideal for distance as well as near field projection. A total lumen value of over 12,000 lumens per light - this light is a powerhouse with a full size form factor and next generation styling. Available soon!
Discussion Starter #2
Re: Baja Designs – New LP9 8-inch Light 12,000+ Lumens
The LP9 just got a little bit BOLDER! [/B]
Introducing a new, more aggressive, cast housing for the LP9. One of the noticeable changes is the larger openings for the Direct Ducted Cooling at the top and bottom of the housing. This will increase airflow to the light and in return keep the light cooler allowing everything to run at peak performance longer. This housing also features a sleek black powder coat finish. Take a look at the website for more pictures and information!
https://www.bajadesigns.com/products/LP9-LED-Auxiliary-Lights.asp
Post up if you have any questions! Don't forget to save nearly $60 per LP9 with your forum discount. Coupon Code: BDForums
-Bailey, Baja Designs
www.bajadesigns.com
Discussion Starter #6
Introducing the LP9 Sport! Available for Pre-Order NOW
The LP9 Sport is perfect for enthusiasts that want the look and features of our successful LP9, but with a little less output intensity and price. The Sport model still includes all of the technology that makes the LP9 series so popular, from Direct Ducted Cooling - that keeps your light cool under stress - to the Integrated Peripheral Technology (IPT), which produces an incredible 200° spread of usable light. The LP9 Sport utilizes 9 forward projecting LEDS to produce 6,500 Lumens at 61 watts, and 6 LEDs for Integrated Peripheral Technology (IPT) which produce 2,550 lumens at 24 watts.
AVAILABLE HERE FOR $459.95
https://www.bajadesigns.com/products/LP9-Sport-LED.asp
Estimated Ship Date - 5/30
www.bajadesigns.com
1 - 9 of 9 Posts
