Bad Axle
2.4K views 6 replies 2 participants last post by  Clothier
Second trip out I ripped the front inside boot on my 2012 RZR 4 800. I figured since it has so few miles on it and I caught it before any water entered I would just replace the boots. Well after fighting to get this thing out, I learned it has been run at such an angle that the inside of the slide was ground and pressed so much that you cannot get the snap ring out to remove the shaft and bearings. I knew I should have just gone ahead and bought the whole axle. Has anyone got any experience with the SIXITY axles? Price looks awesome and I do not want to spend 200 to have a Rhino axle on one side or more to complete them all.
I'm assuming you were trying to remove the cv to put a new boot on correct? If that is the case, you shouldnt have to disassemble the joint. What I do is clamp the axle shaft in a bench vise, use a leather glove or something around it to keep from damaging the shaft. Then I take a small punch, 1/4" diameter or so, and hammer to knock the whole joint assembly off the shaft. Just hit the spur gear inside the joint, the 6 point star looking part, do your best not to hit the cage that goes around the balls it may take a few good hard hits but normally they will come off. Also its the sudden hit from the hammer that will collapse the small clip on the shaft that hold the joint on, so I don't reccommend trying to use a press! I try to keep a few of the small clip rings in my spare parts in the garage, because on older well used axles I have broken the clip when the joint comes off. Hopefully you wont break yours.
In case you do need a clip, here is the part number. Polaris part# 1332542
Expensive as hell, but I have yet to find an aftermarket alternative for that particular size.
I also try to keep a few of the clips where the axle goes into the front diff, they tend to wear pretty quick. Polaris part# 1332539.
Some aftermarket axles do have the snap ring you are talking about, I have some 8Ten axles that do. But the oem Polaris axles have the round circlips.
That sucks. My dealer has the pneumatic fast boot tool that stretches the boot out enough to fit around the whloe cv joint, I've used it several times to keep from disassembling the axles to replace boots. You may want to ask your local shops to see if they have anything like that.
