Hey everyone, I've recently purchased a 2008 Rzr 800, I've had to put a bit of money into it, replacing parts, no big deal. It had a big gun exhaust and K&N airfilter on it, which was too loud for my liking, so I replaced that with the stock exhaust and since then it has been backfiring extremely loudly, same thing as shooting off a gun, so then I replaced the air filter with an original one, still backfires. I replaced the spark plugs, still backfires. However it only backfires when you are going less than 20km, anything faster than that and it doesn't do it. I'm baffled and can't figure out why it would be doing this. I talked to polaris dealer and they said it could be a worn clutch belt, and I also did some research and some people said the stem valve could be clogged. I can't seem to find that though, I assumed it was somewhere around the throttle body, but I'm wondering if anyone can better explain where I can find the valve and if there's anything else that could be causing the backfiring issue, thanks!
