I check and adjust mine on the machine. I just tapped into the two wires (it has 3, I can't remember which colors you need, but there's threads about it on here) with pigtails ending in a butt splice. My volt meter has simple prong ends on the leads, and I slide those in the other end of the butt splice and lightly crimp to hold in place. Makes it pretty easy so you can adjust if needed while watching the voltage. I can't remember the correct voltage either but .739 at idle rings a bell. Idle being 1150-1200.
