Backfire on decceleration
30K views 28 replies 16 participants last post by  crazywatson
Does anybody else's engine backfire on decceleration? I have had mine since June 2008 and it never did it until last Sunday out on the dunes. It backfired three different times that day. The only thing that was different than before was I installed and ran the new bigger stock air filter for the first time. I can't imagine that would cause it to backfire.
my gibson exhust backfires after i floor it for a while. i have a wideband o2 sensor and i am not running lean, if anything my mixture is at 12.5%. 13% is what is recommend for NA engines. everyone trips out behind me, they say i am like a lemans car taking turns
Mine did it too when I just had the UMP air intake on it. It was only after WOT, soon as I let off the gas it would go POP! Then after noticing my head pipe glowing, I also noticed the panel between the passenger and the engine had melted almost all the way through.
After hearing that all that extra air is causing a lean condition, I was scared into buying a fuel controller and an exhaust. $900 later, no more pops, the bed doesn't even get warm enough to warm my gloves up.
Hey Jeff --
When you run Winchester - Buy your fuel from the Boat Marina. It's Hi-Octane -- No Blend !!
This is where I get mine from - They will fill any size gas/fuel approved type of container.
You might have to wait 10 minutes or so after you press the buzzer -- They are extremly friendly and glad to help.
Dave
#21 ·
My 08 rzr is doing the same thing. Backfire when I get off the juice. I have a Dragonfire racing G3 fuel controller that was supposed to take care of the pop but perhaps it is set up wrong?? Anyone have the controller? Any advice. The machine was built before I bought it and I'm not sure how it would be set up. It's cold here right now and maybe that plays a part too?? Any help would be appreciated.
#26 ·
Without an O2 sensor for feed back data it uses a program set up based on rpm tps baro and map sensors and such.
I have recently installed a wide band O2 sensor bought used from a member here.
Also added the Power Commander Ignition module, nice to know I am not running lean
now.
