1 - 4 of 4 Posts
I was comparing my OEM front and back axles and from just looking at them installed they look the same to me but I know they are different lengths. Also the cups looked to be the same diameter, so any way I was looking at my spare axles (tusk) and the front one has a smaller cup than the rear and a smaller shaft that goes into the case I have never had a axle off of one of these things so idk if it suppose to be or did they send me the wrong axle? I know that aftermarket axles and remain axles are all different as far as cup size on cars and trucks is it the same case for these?
Discussion Starter #2
I figured somebody would know?? Lol maybe I will pull it and see and let everybody know.
The cup size may vary depending on the axle, some use smaller CV’s (cheaper) but the front shaft size is smaller than the rear on a non TRE/HL XP1k, so they should be correct as you have them
1 - 4 of 4 Posts
