Hi all,
I have a 2008 rzr 800 with the AWD not working. The indicator light is on, all the gears show up on the display (park through high), I cleaned the resistor pack already, and the ohm readings for the gear indicator are in spec with the manual as I have checked them through the diagnostic mode on the instrument cluster. Should I check the transmission switch or are the ohm readings from the diagnostic mode on the display enough to say the switch is fine. Especially since all the gears display. Every now and then (rarely) the high and park gears don't display but ususally they do. The rzr is off the ground right now and the front wheels do nothing even with the gear on the display and the icon for AWD on the display. Also, in the diagnostic mode the display says "on" when I click the AWD switch. The manual leads me to believe this means 12 volt power is getting to the front differential if it says "on" in the diagnostic mode, is this right?
I am leaning towards mechanical failure in the front differential now. Is this logical? Thanks for any help.
Don
Don
