1 - 9 of 9 Posts
Looking for suggestions on troubleshooting my auxillary outlet not working..checked connections...what else should I look at?
Turn the key on :)?
Do you know how to work a test light and check for power and ground?
It will be one or the other.
if you can test the wires and you are getting power but the outlet still doesn't work check the inside of the outlet. Clear at the bottom in the center is where the + side of your plug makes contact (it grounds through the sides), mine was corroded to the point the outlet wasn't working. I scratched it off with a screw driver (make sure the key is off if you do it that way because if you touch the side and the middle its a dead short and you'll have to find that fuse lol) The better way would be to take the outlet apart and clean it up with some steel wool or light sandpaper but I'm not sure those outlets come apart, I didn't look that close.
They come apart.. The inside unscrews. The wires can be unplugged and the outlet removed pretty easy.. The outlet is not a sealed outlet like you would see in a boat.
1 - 9 of 9 Posts
