I wanted a reverse light on my 22' PXP4 for both sight when backing up and also for a rear light to see into the bed and as a utility light when needed.
This is not an advertisement, Just figured others maybe looking for something like this.
I saw there where a few posts where people had made one with limit switches, but I really wanted a more plug and play option.
I Found the Powermadd RZR -General reverse light kit 66008 Amazon.com
it was generally plug and play.
non-plug and play options I took
1. I decided to purchase a pulse bar plug and wire that up as the power source. Amazon.com
2. I decided not to use the provided round on/off rocker switch, and used a 7 pin that matched my other switches and would fit in the accessory panel. (Power wire goes to pin 2, and the Ground wire goes to pin 3) Amazon.com
3. I also decided to use a 14" light bar in place of the provided light (I wanted it really bright!) Amazon.com
Other than fishing the wires through the console it was simple to wire up, it uses a plug into the transmission where it recognizes when you are in reverse, but also allows for you to use the bi-pass switch for when you need the rear light.
I purchased this though my local dealer, because I had a credit with them. but can also be purchased online.
