1 - 10 of 10 Posts
Brian over at Rockcrawler.com recently installed the ATR V Brace Dash Bar with Mounts for the Rigid Industries 30" LED Light Bar.
ATR Dash Bar – RockCrawler RZR | RockCrawler 4x4 and Offroad Magazine
If you play at all, you are going to flop your RZR…if you play hard, you are likely to do a full roll. And if you’ve spent any time researching on the internet, you’ve seen the images of the RZR A-pillar bent to one side or the other following a rollover. The stock RZR rollcage is not the strongest, and while plenty of high quality full replacement aftermarket options exist, there are improvements you can make to your stock cage that will greatly strengthen it and save some money…this is why I chose to install the All Terrain Research Dash Bar w/ V-Brace.
The Dash Bar is designed to tie in the two bolt-together stock mounts at the dash and add rigidity to that point. Adding the V-Brace adds still more strength by tying in the Dash Bar to the center of the A-hoop…this combination of mounting points adds triangulation to the A-pillar and helps keep this pillar intact during a side roll.
Read More Here...
ATR Polaris RZR Roll Cage Dash BarsA
We also make this without the LED mounts. This is the strongest intrusion bar on the market. We paid special attention to the clamp area so that you get a streamlined look with the added security of clamp redundancy!
1 - 10 of 10 Posts
