1 - 12 of 12 Posts
Our Polaris RZR Solid Shift Kit includes CNC machined shift handle, preload washer and bronze bushings that replace the factory plastic bushings and take out all of the loose play in the factory shift lever. Unlike other shift handles on the market the ATR handle is keyed so that it will not spin loose. It bolts in like the factory shifter from the top and the machined cap is held on with a set screw. This is a much better design instead of expecting one set screw to keep the handle from spinning.
ATR Polaris RZR Solid Shift Kit $145
1 - 12 of 12 Posts
