1 - 9 of 9 Posts
Our new Polaris RZR rear sway bar offers an increase in performance and strength over the stock unit and also has the added feature of quick disconnect links. This allows you to have the best of both worlds by being able to quickly disconnect your sway bar for added suspension articulation for trail riding, and reconnect it for more stability for higher speed riding.
Sway Bar is a bolt in replacement of the stock unit and takes about 30 minutes to install. ATR Sway Bar features 4 chomoly rod ends that allow for bind free movement and are teflon lined to ensure long life. Sway Bar links come in a zinc plated finish. Quality Bowtie style pins are used to be able to quickly disconnect and reconnect sway bar.
ATR Polaris RZR HD Rear Sway Bar with Quick Disconnects - $445
"increased performance and strength"
Other than the links what other performance values does this sway bar offer over the OEM one ?
is it a lower rate or a higher rate ?
I'm curious too... Wouldn't the "bind free" rod ends allow for more suspension articulation than the stock bars? The Polaris sway bars basically make the machine feel like a solid rear axle to me...
1 - 9 of 9 Posts
