101 - 120 of 223 Posts
'21 Pro XP4 Ultimate Rockford Fosgate LE
Discussion Starter · #105 ·
Haha, I'm off trail 8 about one mile West of Marquette. Cool ride man! I especially like the star light liner, pretty unique. (y)
I'm sure I've been right by your place then, we ride through that way a couple times every year. I always b!tch about the Harvey speed limits but make sure to stop at Lakenenland. Thanks for the compliment, pretty happy about this machine overall. It's the most comfortable riding machine we have had and makes the long days easier on the body for sure.
Once the border is open again we're going to plan a loop around Superior. Did it on snowmobiles (in 7 days) and the wife wants to do it on the machine (probably a lot longer than 8 days). Planning routes now, will let you know if we make Marquette an overnight stop - would be cool to meet up with someone from the forum. 👍
2021 Polaris Rzr XP PRO 4 Ultimate
I thought about it but figure for the price of the separator I can buy a lot of filters. I'm typically trail boss on rides so i don't have to contend with a lot of dust. May change my mind later, if you have any input I'd like to hear it.
I can't say the stereo is worth the upgrade, I know I could've built better cheaper (maybe) but it is a great setup from an OEM standpoint. I am adding a ground loop isolator and timed relay as I do have some power down issues giving feedback through the right front speaker. The deciding factor was really about the color and LE status. Pretty vain answer but having a limited supply of similar machines is a plus for me - even though I'll customize the heck out of it...
i too have the pop from right front speaker when shutting down my 21 pro ultimate. where can i find the fix that you did?
Discussion Starter · #107 ·
No fix yet, it's not released to my knowledge. Polaris will be sending an update for the ride command to download and install. In the interim I am just making sure that if I power up the key that it plays music before I shut it down. That has helped but it's still present.
Discussion Starter · #108 ·
I planned on running an ECM tune so as to not feel like I was being governed when the computer throttled back the motor at speed so I called Terry Gilomen at Gilomen Innovations and inquired on his setup. He's done all my Polaris machines in the past and I have never had an issue with anything that he wasn't prompt to help me fix so my loyalty brought me back there with this machine. The new Wideband Bosch ECM with his tune arrived this morning. Will be a bit before I get to the cabin to try it out and determine what changes I will make to my clutching. The updates will come accordingly.
Wheel and tire selection actually became MUCH more involved than it probably needed to be. I studied this forum for size recommendations and fitment issues then moved on to rotational inertia / mass formulas and impacts of wheel/tire weight on performance. I didn’t want to create a longer turn radius on this by adding forward arms so I limited my tire size to true 32” at most. I found the Maxxis Carnivore to be suitable for the various terrain I ride and the 32x10R15 8 ply was my best choice from a weight perspective. I looked into available wheels, compared their mass and found the MSA Diesel in 15”(+10mm offset) to be about the strongest and least amount of weight from the stock wheels. From stock I only added about 2.6 pounds per wheel/tire going to this setup. The equivalent impact on performance is like adding about 16.64 pounds of weight to a stock machine.
676336
Looking forward to the installed pics! I'd be interested in your stock set, if you're selling! Road trip from the north shore of Lake Superior!(y)
  • Like
Reactions: Arcticzale
Discussion Starter · #110 ·
North shore?!? Know a couple folks that way, you in Ontario or by the Boundary Waters?
Probably won't part with the wheels but appreciate the offer. With a limited build I want to keep the stockers for the next owner. Will certainly get some pics up, but I'm on the road a few weeks. Also have some solutions for airflow to control intake dust that I have to get installed.
I'm in MN, plenty close to the Boundary Waters! We ride right along the border (both BW and Canada) with wheelers and sleds. Got to be careful on some of the lakes in winter, as some aren't marked well, and the line runs down the middle! Keep up the great work, lots of great ideas!
  • Like
Discussion Starter · #112 ·
Love the boundary waters, Gunflint trail is great! I run through there every couple years or so. Like to do some Caribou Island cruising too. The ride from Kakabeka Falls to Gunflint is pretty great in the winter as well (when there's enough snow) but I've never been in the summer. I'm about opposite across the lake where Superior meets the St Mary's river. 👍
Discussion Starter · #113 · (Edited)
Finally got to get the wheels and tires installed this evening. I went with the MSA M12 Diesel in 15" because it was the lightest 15" wheel I liked and the 32x10r15 Maxxis Carnivore. These tires served me well on my ranger and work great for my riding style on our trails up here so after much debate I decided to stay with them. I do really like the look, but kinda wish the wheels were gunmetal to match the roll bar like the stock ones. May have to paint or powder coat these over the winter.
I also installed a new ECM from Gilomen Innovations at the same time. Frankly, I'm impressed. The combo matched up really well in my road runs with the factory clutching and my rpm stayed from 8500-8600 on shift out with just me in it. Throw another couple in the back seat and I'm sure it'll run right at my target 8400-8500. (Excuse the mess in the garage here, been a chaotic summer)
Tire Wheel Automotive tire Hood Vehicle
Wheel Tire Car Vehicle Hood
Tire Wheel Vehicle Car Hood
Have some wheel rings LEDs that'll fit around the brake rotor and should look pretty sharp. That'll be a fall install once I confirm they won't interfere with the tracks.
Tire Wheel Vehicle Automotive tire Hood
Discussion Starter · #114 · (Edited)
Also installed the wind wings I made. Saw @Roger Lee "s post in another section and liked the idea of drawing clean air back to reduce the low pressure areas. Just made this set using Ram Mount arms and some black plexi. I'm hoping for good results, appreciate him sharing the idea. Raining here tonight so won't get to test for dust tomorrow, will update accordingly when it dries up.
Motor vehicle Tire Hood Automotive tire Vehicle
Wheel Tire Vehicle Hood Motor vehicle
Discussion Starter · #115 ·
Had a sheet of GlowOn phosphorescent tape that I trimmed up and put over the covers for access to the door handles. This will make it less of a hunt for opening the doors in the dark. This stuff glows super bright and holds a charge for hours.
Green Rectangle Yellow Wood Creative arts
Hand Rectangle Creative arts Finger Art
Just put some small pieces on the covers.
Vehicle Car Automotive tire Hood Motor vehicle
And made sure to put some on the interior buttons for the latch.
Hood Automotive mirror Motor vehicle Automotive lighting Trunk
Here's how they look in low light.
Hood Automotive lighting Trunk Bumper Wood
Here's how they look in the dark.
Automotive lighting Astronomical object Electric blue Font Space
Just an easy little upgrade that's going to be functional as the days start getting shorter.
Discussion Starter · #116 ·
Got the hydrographics on the hood scoop, going to run it to see whether it keeps the floors cooler this weekend. Looks like cooler weather ahead so it might not be noticeable as to whether it helps keep the floor heat down so I'm going to wait to clear it. I did notice running the Gilomen tune with the fan coming on 10° cooler that the heat wasn't as unforgiving.
Grille Hood Automotive tire Automotive lighting Motor vehicle
Hood Automotive tire Trunk Motor vehicle Bumper
Hood Rectangle Bumper Grille Wood
Table Bumper Automotive exterior Gas Rectangle
Really loving your build, Articzale. You are a fountain of information. I’m in the middle of upgrades on my 2021 RZR Pro Ultimate RF LE. The color was what really sold me on Ordering it over regular Ultimate.
Discussion Starter · #119 · (Edited)
I agree, we were actually waiting on the 72" model and once this was released we ordered. Was ordered March 3rd, day after the release - mostly because of color and because my local dealer was selling at retail we went with I-69. Saved about $4,000 and spent $700 in fuel hauling the trailer to pick it up. Wife likes Blue, so blue it is. 👍👍
Discussion Starter · #120 ·
Got the hood with the scoop on, color is off so I'll do it again. But will run it this weekend to see if it makes a difference on the heat to the floorboards.
Wheel Tire Vehicle Hood Automotive tire
Automotive lighting Hood Motor vehicle Vehicle Bumper
Also installed the Factor 55 winch hook. Really like the look, functionality test will surely be this weekend...
Tire Wheel Automotive tire Vehicle Hood
Tire Wheel Automotive tire Motor vehicle Automotive lighting
