The NEW CARBON Stow-N-Go HD Series features a NEW molded bottom like our Hybrid Series. This cooler is perfect for all of your off-road adventures. Fits great in the back of your UTV or in shallow places. Made with a sleek carbon vinyl exterior, which makes it easy to clean. The new molded foam bottom will eliminate abrasion and scratching, while also help to retain ice and keep drinks cold. The dimensions are 8.5 Tall x 23 Long x 15 Wide. It will hold 38 cans, plus 20 lbs. of ice. The height allows you to use the cooler where other taller coolers won’t fit. Whether you have a ski boat, fishing boat, off-road vehicle, or RV, our new Stow-N-Go HD series will fit where the competition doesn’t.
Features:
- Made with heavy duty 1,000 denier UV and Mildew resistant Vinyl with a carbon fiber pattern
- Features a hard-molded foam bottom to protect from abrasion and heat
- Leak Proof, Eco-Friendly welded TPU (Thermoplastic Polyurethane) that has physical strength and elasticity making it abrasion resistant
- Insulated with ¾” think polyurethane high density closed cell foam, which air cannot pass or be blown through
- User friendly, double, solid, non-corrosive YKK Zippers
- 1” AO Logoed webbing that includes 4 d-rings to tie down
- 4 Padded Grab handles for easy transport while loaded
- Includes a top pocket for dry storage and easy decoration
Dimensions: 23”L x 15”W x 8.5”H
$149.95
LINK: AO COOLER STOW-N-GO HD
