1 - 2 of 2 Posts
· Registered
Can you just plug it in add the 02 SENSOR and ride. Or do you still have to tune it in.
Just wondering if it is worth the money. By the way, I have a Trinity 820 big bore with a web cam. That is way I need a fuel controller. The one I have is not cutting it.
· Registered
You can do the install, make sure the shunt is in place on the expansion port or it will not recognize the auto tune portion.
Load a program similar to your motor setup and have the auto tune table AFR set at 13.2
and have the auto tune switch turned on and it will run good.
It can be fine tuned further from there using the laptop.
I am getting about to that point learning to use it.
Definitely a good setup, am considering the LCD unit too.
1 - 2 of 2 Posts
