I bought the Polaris 3500 lb winch and noticed that after installing it that it is almost impossible to grease the upper a-arm. The stock zert was rubbing against the winch and will eventually rub a hole in the winch housing due to the a-arm moves up and down as you drive. I know it will take a while to make a hole.
I went to the local hardware store and even purchased a low profile zert, but it still isn't low enought. How in the heck do you put the grease zert gun fitting on the zert without removing the winch everytime.
I was thinking about drilling another hole in the a-arm on the side, but that might be a weak point. I believe the threats are 1/4-28. I found a flush style grease zert by Master-carr, which might work. Any simple fixes guys.
