1 - 5 of 5 Posts
I just got a 17 XP4 Turbo and was primarily going to Pismo .
Going to get paddles but saw the Tribute tires which seems like a good option for the front. Just in case you need some 4x4 to get you out if needed .
They are a 29" tire and most rear paddles are 28 or 30 .
I remember that with paddles that were measured on the shallow or non paddle diameter .
If that is still right a 30" paddle would work
. I just don't want to damage the 4x4.
I run Tributes on my 18 Turbo S. STU Paddla Trac on the rears. I like how the Tributes help “pull” the machine in 4WD and reduce the plowing effect in turns. I like them better than the STU Razors I have on the front of my 16 XPT.
Late to the party and I'm sure the input is irrelevant at this point, but I am running the full STU setup on Ruby. Tributes up front with the SR-31 Blackbirds with #2 cut in the back.
Absolute beast mode with this setup!! She pulls so hard!
659089
1 - 5 of 5 Posts
