1 - 4 of 4 Posts
Does anyone know if the center caps bolt on to these wheels or do they use the same cheap setup as the Stock Polaris Wheels? Wire ring and plastic clips, that either the plastic tabs break or the whole center cap falls off the wheel when you ride rough terrain. Are they a good Quality wheel also.Thanks
I run Raceline Mambas single Beadlocks and have been hard on them with no issues. The center caps just snap in like Polaris caps.
Jumpman23
Like stock but they stay put much better than the stock Polaris center caps. I broke one rock crawling and took another out on a log. 12.00 fixed each one. I had Polaris caps fall off on whoops without even touching them.
1 - 4 of 4 Posts
