I didn't want to see this I just bought a Fusion for mine. Hope it holds up.
On a good note they have a warranty. I sent mine in with good initial communication from Fusion. I have read that you should put some sort of voltage regulator on the deck. Not sure what one yet but when I find out I will post.I didn't want to see this I just bought a Fusion for mine. Hope it holds up.
I've been really happy with my Jensen HU.And recommendations other than the typical Marine deck?
I have a friend with that Jensen head unit. It seems to work out good for him. If getting the Fusion deck fixed does not work out I might go that rout.
That would be greatly appreciated. Thanks. My battery set up is stock and the deck is connected up directly to the battery but does shut off with the key.Stprzr, well congrats on that stereo rig, it definitely looks nicer than the older one.
Sorry to hear about the power/blown issue. I heard what battery you are using may have something to do with it (optima I think).
I've had mine in for at least 50 hours of run time with no problems. It may have to do with the power source or power lead you are using. If you need, I'll look when I get home to see what lead I'm using for my stereo.
That might be the issue dude. I get home tomorrow. Pm me tomorrow or the next day to remind me.That would be greatly appreciated. Thanks. My battery set up is stock and the deck is connected up directly to the battery but does shut off with the key.Stprzr, well congrats on that stereo rig, it definitely looks nicer than the older one.
The ground goes all the way back but I think the power splices into something under the deck. Probably the accessory plug.That might be the issue dude. I get home tomorrow. Pm me tomorrow or the next day to remind me.That would be greatly appreciated. Thanks. My battery set up is stock and the deck is connected up directly to the battery but does shut off with the key.Stprzr, well congrats on that stereo rig, it definitely looks nicer than the older one.
Mine is also Keyed on/off, but it was a hot lead already in place. Did yu actually run a wire or did you use something that was existing under the dash?
One last question, did you talk to your installer and ask wtf?Thanks, I like the clean look too. That is why I want to stick with it. I didn't install (local stereo shop) it so I don't know why they went all the way back but it is a fused line. But it didn't blow the fuse when my HU took a dump. Maybe its to big of fuse. I think it was a 25amp....maybe 20.
As long as it doesn't blow, you will probably end up lovin' it. Good Luck.Well I'm stuck with the fusion hopefully it holds up. I built a custom fiberglass box for the roof. Its built to the fusion and 2 6x9's. Don't have any room for anything bigger. I already started glassing the box. I was going to just run the power off the amp power lead. Fusion has a fuse in the back. Ing power lead will be on a switch. Also built a 10" sub box for under the dash. I hope it sounds good have allot of time in it. I'll post pics when i'm done.
That sounds cool. I would for sure use some sort of regulator. I will post what Fusion tells me to use when I talk to them next.Well I'm stuck with the fusion hopefully it holds up. I built a custom fiberglass box for the roof. Its built to the fusion and 2 6x9's. Don't have any room for anything bigger. I already started glassing the box. I was going to just run the power off the amp power lead. Fusion has a fuse in the back. Ing power lead will be on a switch. Also built a 10" sub box for under the dash. I hope it sounds good have allot of time in it. I'll post pics when i'm done.
